NEED BIG help choosing Charge Controller/controllers please?
Guys I keep saying that despite the math and any other factors, with my system, with 4 panels to one CC at the height of the day delivered 50amps(maybe 51). I was there I recorded it. So , not in theory but in factual actual reality, with 4 more panels to one other CC I will be receiving exactly 100amps to battery bank(maybe 102).Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Its coming together, ..slowly lol
Btw does anyone know of a decent high amp(50amp maybe) 110v(generator or house powered), 12/24v battery charger?Comment
I use a Craftsman Platinum. It has 2, 15, 40 and 125 i think are the levels. It is not a floor standing model. It has battery type choices which include their Platinum AGM battery. I've used my pretty often to maintain a few cars that dont get driven enough. They run about $89-99.Comment
You can also get a parallel cable and combine the output of the two of these together. It can sustain 1600 watts, and 1600 / 12v = 133 amps, however I would suggest running at 1/2 - 3/4 capacity for best efficiency. It does have DC output as well, but I would get a good three-stage charger and run it off the generator. I suppose you could also get a DC-DC charger but an AC charger would be more versatile IMO.Comment
Yes, here it is on Amazon -> http://www.amazon.com/Smarter-Tools-...5%3A2470955011
This is the newest equivalent version of what I have.
I don't know if 40amps will charge my 1200ah battery bank. I've seen some commercial units that charge @20/50/80...Expensive tho.Comment
The very best one I can quickly find for 24V (28V needed to charge 24V battery)
DLS This product webpage has been discontinued, please see the suggested products below or contact your local sales representative.
40A @ 28V, about 1,242w input consumption. Much higher input needs to go to 240V because standard household outlets are not rated for higher power long term.
For 12V, I have a VEC1093 12V Charger (now branded as Black&Decker) and it has a 40 or 50A mode.
SPECIFICATIONS DLS-UI-27-40 CONVERTER / CHARGER
DC Output Voltage (No Load) approx. 27.2V (DC)
Output Voltage Tolerance (No Load) + or - .5%
Output Amperage, Max Continuous 40 Amps
Output Voltage (Full Load) approx. >27.0V (DC)
Maximum Power Output, Continuous 1100 Watts
Ripple and Noise <100 mV rms
Input Voltage Range 108-264V (AC)
Input Voltage Frequency 47-63
Maximum AC Current @ 120VAC 11.5 Amps
Power Factor (@ Full Load) >90%
Typical Efficiency 80%
Max Inrush Current, Single Cycle 75 Amps
Short Circuit Protection Yes
Overload Protection >100%
Line Regulation 100 mV rms
Load Regulation <1%
Fan Control Proportional
Thermal Protection YES
Working Temperature Range 0°- 40°C
Storage Temperature -20° to 80°C
Withstand Voltage (VDC)* 1700/1700/500
Dimensions 13" x 8.3" x 3.4"
Weight 9 lbs
Input Cord** IEC C-14Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
