> Can you tell me what size wire is between the panels and controller?
The diameter of wire from solar panels to controller is about 2mm
> We would need to know the panel specs manufacturer and open
> circuit voltage and location for coldest recorded temperature.
I try to determine this information. But at the moment it is not easy, because the panels
are placed on the roof.
The solar panels are installed in Cambodia.
Here is the same temperature whole year - about 25 - 30 degree celsius.
The system at my home looks like this:
What is the exact difference between "Morningstar TriStar MPPT 45 Amp" and "Morningstar TriStar 45 TS-45"?
Because I see that both controllers do almost the same, but die MPPT controller cost much more.
