PV to THNN/ THWN connection
Well, after a tense few emails we had a discussion that ended favorably for me. In the end he agreed that the manual DC disconnect at the barn would serve no real purpose, and I get to have a junction box after all.
Thanks again
SDComment
Interesting, I just went through this exact process myself. Ground mount with Rapid shut down. I contacted a solar installer to do the final hookup and they wanted to add dc disconnects at the array(would need 3 disconnects for 3 strings). When I questioned the need, they insisted that "it's just how it's done". I ended up wiring it myself with a simple junction box per the three line. I used wire nuts.
Inspector said it was fine. With RSS the need for one DC disconnect is questionable, why would I want another set??Comment
Remind the inspector that an MC4 connector is rated as a non load break DC DisconnectInteresting, I just went through this exact process myself. Ground mount with Rapid shut down. I contacted a solar installer to do the final hookup and they wanted to add dc disconnects at the array(would need 3 disconnects for 3 strings). When I questioned the need, they insisted that "it's just how it's done". I ended up wiring it myself with a simple junction box per the three line. I used wire nuts.
Andy
What about using an MC4 connection - would they work better? Can they be used in a junction box?Comment
MC4 connectors work well when installed properly. Of course, the problem is, installing them properly without expensive crimp toolsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I don't know about MC4 crimp tools, but there are some respectable Chinese crimp tools on the market now in the $20 price range.7kW Roof PV, APsystems QS1 micros, Nissan Leaf EVComment
