Ground Mount Advice - Unirac Vs Iron Ridge
  • Bloomj
    • Mar 2019
    • 3
    I'm getting ready to install a 28 PV array and am between two ground mount racking setups.
    Iron Ridge seems the most obvious and I like the landscape layout it offers. I'm a bit concerned of the headaches associated with landing two rows of 10 piers in a perfectly square / parallel configuration to make it happen.
    unirac cantilever design seems better due to only requiring one row of support posts but it only does portrait layout which makes it longer. In addition, I've read all of documents I can find and am still unclear as to what size/ depth of concrete pile it would require me to use for each pier.
    does anyone have any experience and advice to offer?
    thanks,
    joshua
    Last edited by Bloomj; 03-11-2019, 10:37 AM. Reason: Iron ridge ground mount unirac installation racking
    • 15193
    Hello Bloomj and welcome to Solar Panel Talk.
    There are a number of members that have installed (or built) a ground mount system. They should be able to give you some pointers on which direction to take.
    Just be aware that due to wind loading and local building codes the amount (or number) of concrete piers for a system will be different. The best info is to talk to your local code people and see what they want and will agree to if you perform a DIY system.
      • 5235
      thanks, joshua
      With a ground mount, you might want to consider a setup which allows easy tilt change for
      summer and winter seasons. This gets more important if you get snow. This one has proved
      its value for a year. Bruce Roe
        With the dual legs that one maybe didnt required as much concrete as a single pole might.
          • 5235
          Not sure, the underground part for 6 pivot mounts is 77 bags of concrete and 240' of rebar. Post
          holes are a problem here with the rocks, so 6 trenches went front to back. Those pivots need to
          stay aligned, so the front and back are connected at the 4 foot depth. 24 panels. Bruce Roe
          • littleharbor
            • Jan 2016
            • 1998
            Bruce, Can your panels lay fully horizontal which could be very beneficial in an expected high wind event?
              • 5235
              They certainly could, used that position to throw the panels up. Its designed to swing 90 degrees
              from vertical to horizontal. But doubt I would ever do that for wind. Bruce Roe
              • Bloomj
                • Mar 2019
                • 3
                Thanks for the replies. I don't think I need to pivot the array. We don't get much, if any snow here in South Carolina.
                I'm now considering MT Solar.
                • gbynum
                  • Dec 2014
                  • 65
                  There is a website that gives suggestions for 2 and 4 times a year angle changes to increase harvest. I don't recall it, but Google will help you. The greatest improvement is a change in spring and fall, flatter during summer, more vertical during winter. PVWatts will help you quantify improvement.
                  I'm in Greenville SC, roof mounted, about 50 degrees (far more vertical than optimum). I get better performance in winter than others do, but poorer in summer (and annualized) than I would at a flatter angle.
                  • littleharbor
                    • Jan 2016
                    • 1998
                    Solar tilt app. Very cool as you can find exact tilt, any day of the year and anywhere on earth. GPS for you location and built in tilt gauge for setting your panels angle.
                    • Bloomj
                      • Mar 2019
                      • 3
                      I would be the same if I roof mounted mine. That's one reason I'm going ground mounted. Going with Unirac.
