Panels mounted to a Fence
I have a shed in the corner of my yard that has 2 homemade panels that I was testing. Their are no other panels on houses in this neighborhood.Comment
Either I am looking at the wrong address or Google Earth is wrong. But it is showing 2 houses on Summer Lane with solar panels which are just a couple blocks to your west.Comment
Ampster that is a good ideal I could have a row of 10 panels with an 80 degree angle and then I would have room for the lower row to be at 40 degrees or less depending on the 2 foot gap to the property line. I will play with those numbers and see what that will do for my spacing.Comment
Thanks. I didn't respond to your other thread about inverter choices because , if you are using a string inverter, a lot depends on your array configuration . My only experience is with Outback and Solaredge. I did purchase some Tigo optimizers to use with mybOutback inverter string. I believe Tigo was purchased by SMA.Last edited by Ampster; 03-05-2019, 09:58 AM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Ok I got the project done. Here are a couple of pictures. 26 panels 325 w each with tigo optimizer and a 7000 sunny boy inverter.
IMG_20190502_143330311.jpgIMG_20190502_143251976.jpgAttached FilesComment
