Best Mounting Option for Rock-Covered Roof?
As you SHOULD know HOA has nothing to do with safety or building codes. Further the codes and requirements do not distinguish based on quantity of solar modules.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Trust me, when that happens you don't want to be the one holding the bag.
BD suggested ground mounted posts just for experiments; you can make racking or even rails from wood if you like, just make sure panels are well attached to them. Proper long term ground mounts would also require permits and visit to your local building department. It's not that bad, just a little overwhelming at first.
From what I see, the newer the panel, the less metal is in the frame. The weak point may be the panel
attachment to the support, I can imagine it being ripped off before anything else lets go. I am not getting
excited to use 6 or 8 bolts, though. Bruce RoeLast edited by bcroe; 08-23-2017, 09:40 PM.Comment
Unless you are technically and legally qualified to render an engineering opinion on structural engineering, and also prepared to back up that opinion in court, what you may think probably doesn't matter much. Short of that, follow manufacturer's recommendations as f(local codes) require.Comment
