We recently bought an off-grid home and had the solar system upgraded to 1800w with new inverter and additional battery capacity (48v). I've really enjoyed learning the system and working with the installer during our system upgrade and would like to install an additional set of panels that will be located in a different area from my current set and want to utilize the same charge controller for both arrays. What is the best way to connect the outputs of both combiners?
System Specs
Charge Controller - Schneider MPPT 60 150
Array 1 combined output: 23.94 Imp / 75.2 Vmp
Array 2 combined output: 17.38 Imp / 73.6 Vmp
Would this be just a simple matter of adding an additional combiner box at the charge controller with large enough breakers/fuses to accommodate each output?
System Specs
