Announcement
No announcement yet.
Sealant Recommendation
  • Filter
  • Sealant Recommendation
    What sealant do you guys recommend for a comp roof?
    Thats all, pretty simple, just looking for some feedback so I can do my own research.
    Thanks all.
  • #2
    Thanks all.
    I think what you want is to look at flashing like ironridge flashfoot:
    http://files.ironridge.com/flashfoot...Tech_Brief.pdf
    or quickmount:
    http://www.quickmountpv.com/products...ion-mount.html
    • #3
      or quickmount:
      Even with a flashing, most manufacturers still recommend you add sealant to the hole. I can't remember what kinds are recommended, but if you call QuickMount's customer service, I believe they can suggest a good product.
      • #4
        or quickmount:
        Thanks butch, already decided on the Flashfoot for my application, it just looks too easy.
        Still everything I have read says
        1. I will poke some holes in my roof that I do not need, and even though they will be protected by flashing I should still fill them with a sealant.
        2. I should put sealant in the hole before I drive the lag bolt
        3. To add some sealant in a U shape to the bottom of the flashing to shed water away from the penetration point.
        Henry's 208 seems to be popular, but I was wondering what you guys recommend.
        • #5
          yes just wanted to make sure you were not planning on using L-Feet and sealant without flashing.
          • #6
            Read an article recently, apparently that used to be standard practice, too funny.
            • #7
              Fwiw, the installers used M1 on my comp roof using flash Lfoot brackets. We don't get much rain here, almost no real wind, and winters barely reach 32f on a few days.
              • #8
                Hopefully you'll have good luck hitting the rafters, and will do well at drilling the holes perpendicular to the roof.
                I used Loctite PLS30.
                Hopefully that was a good choice.
                This is a material selection choice that took me a while to decide which to go with. Even after spending a fair amount of time researching, I didn't feel like I had a good grasp on whether PLS30 or other options would be the best for my roof.
                • #9
                  Thanks foo1bar, your experience is exactly why I asked. The few reviews I found are very promising.
                  • #10
                    I use geocel proflex clear. That way when it inevitably gets all over your hands it doesn't turn them black. Good sealant too.
                    Ben
                    • #11
                      Ben
                      I use that stuff on my RV, very sticky stuff.
                      • #12
                        Another vote for Geocel
                        I Used Geocel 2300 Clear. Best stuff I've ever used. It is firmer than silicone and is almost workable like a mortar would be.
                        I had difficulty finding it locally and most online places were pricey. I ended up ordered 8 tubes from Seamless Gutter supply of Maryland for a very fair price.
                        It also worked great for sealing around my Soladeck. A flattened bead at the junction between the shingles and the Soladeck and some granules out of the gutter to finish it off really worked well.
                        • #13
                          Had this exact question this weekend! I mounted 28 Flashfoots (flashfeet?). Used a Loctite product tube, and then Henry 209. All of it was messy, gross, and smelly!
                          I also bought some metal "shingle" repair pieces, since I accidentally drilled in a few places I shouldn't have.
                          On my roof, I found the "roof dance" worked exceptionally well. I don't think I missed any that way. I initially tried the drilling up from the attic, but that was too cumbersome.
                          I was working alone, and found it helpful to drill one set of rafters, screw bolts in a tiny ways, and use those to hold the chalk line for the horizontal row. Before I discovered this, I made a pretty wavy line of mounts Hope the rail can adequately bend to compensate.
                          • #14
                            Awesome tips, thanks. I will be doing much of the work myself too.
                            Plans are submitted to the utility and waiting for their letter of approval. It's a long shot, but I am hoping to be installed by end of year, maybe not connected, but at least installed. Hopefully the weather plays nice with me.
                            • #15
                              Thanks for the tip on Seamless Gutter. By far the best price on Geocel I could find.
