solar output paralleled with wind turbine output
  • myzter
    • Jun 2010
    I was thinking about pairing solar cells output with a wind generator output.
    solar cells in parallel for max amps, and in parallel with the output of the wind turbine to reach a higher voltage..
    Would this work ??
    Do the solar cells need to be @ a specific end of the circuit or in a specific configuration ??
    I look forward to reading forum members thoughts, even if the idea is incorrect.
    Each device (PV & Wind gen) needs it's own controller. The controller for the wind gen must have a dump load capability, and a load large enough to handle the full output of the wind gen. Better still, if your wind gen has a brake that the dump load can apply, and save your bearings in a windstorm.
