I was thinking about pairing solar cells output with a wind generator output.
solar cells in parallel for max amps, and in parallel with the output of the wind turbine to reach a higher voltage..
Would this work ??
Do the solar cells need to be @ a specific end of the circuit or in a specific configuration ??
I look forward to reading forum members thoughts, even if the idea is incorrect.
Would this work ??
