Getting SMA's web connect to work on WIFI?
  • garybeck
    I just installed one of these. A bit less expensive than what you linked, and it has two ports, which you might not need but I did. Set it in "Client" mode, and it connects to the Wifi network and allows hardwired connections. Not too hard to set up, it will even search for available SSID's and list them by MAC Address. It was helpful for me because I have two access points with the same SSID and wanted to make sure it was connecting to the right one.
    thanks. were you using it with the SMA web connect?
  • garybeck
    started a topic Getting SMA's web connect to work on WIFI?
    Has anyone here tried to get SMA's Web Connect to work on wireless? It requires an ethernet connection of course, but there is no ethernet available at the site of the inverter for an installation I'm working on. There is WIFI. I thought about using one of these:
    http://www.amazon.com/TP-LINK-TL-WA8.../dp/B00E98O7GC
    It mainly is designed to receive a wireless connection and "repeat" or "extend" the signal, but I noticed it also has an ethernet port on it.
    I haven't tried it yet.... wondering if anyone here has. I called SMA and they said it "should" work but they wouldn't support it.
