Sucess at Last
Hi People that helped, finally worked.
I just need some data now and im sweat
thank you so much for being so kind and helpfull
Its people like you that make the world a better place..................you know who you are,,,,,,,,,
thank you
chris
Getting SMA's web connect to work on WIFI?
Thankyou so much I ll try ASAPStep 1: Configure the hard wire ethernet on your computer to be DHCP. That is the default setting for most.
Step 2: After plugging in the WR710, connect it to your computer's ethernet port.
Step 3: Log in to the WR710. Default IP address is 192.168.0.254. Default user name is admin, default password is password, I think. If that isn't right, check the label on your WR710 for correct info.
Step 4: Click on Quick Setup. Follow screenshots below.
First, choose Client
[ATTACH=CONFIG]7376[/ATTACH]
Then, click on Survey
[ATTACH=CONFIG]7377[/ATTACH]
Your desired wireless network should show up in the list. If you have multiple access points, you can use the signal strength or MAC address to mac sure you pic the right one. Click Connect on the right.
[ATTACH=CONFIG]7378[/ATTACH]
Your network information should populate. Enter the password for your wifi network in the box near the bottom.
[ATTACH=CONFIG]7379[/ATTACH]
It should connect at this point. If you'd like to assign a fixed IP address, you can do that in your main router, and also in the Network menu option of the WR710.
[ATTACH=CONFIG]7380[/ATTACH]
You can test the functionality by shutting off wifi on your computer, and prove that you still get internet access via the WR710 when you are hardwired in.
Now, you can unplug the WR710 from your computer, and plug its ethernet into the inverter, or whatever remote device you would like to connect to wifi.
Let me know if you have any questions. It has been a couple months, so there could definitely be a step I'm forgetting in there somewhere.
Cheers chrisLeave a comment:
If you cannot setup a wireless unit by following the user manual, then just get a powerline unit, plug-n-playLeave a comment:
Let me know if you have any questions. It has been a couple months, so there could definitely be a step I'm forgetting in there somewhere.Leave a comment:
Hi purchased the tp link and cable spent ages trying to get if to work no joyThanks for the tip on the wireless adapter. I picked up the single port version WR700N in advance of getting my system installed with SMA inverters. Setup was a snap, and tested it using my laptop (turned off the wireless on the laptop, plug into the adapter, and I was surfing in no time). I have easy access to run the CAT5 from the Webconnect cards to the router, but this will save me that step. Slick little device for $20 that's for sure. Now I just need my installer to get here!
Anyone know if there is an idiots guide for client mode
AhhhhhhhLeave a comment:
Thanks for the tip on the wireless adapter. I picked up the single port version WR700N in advance of getting my system installed with SMA inverters. Setup was a snap, and tested it using my laptop (turned off the wireless on the laptop, plug into the adapter, and I was surfing in no time). I have easy access to run the CAT5 from the Webconnect cards to the router, but this will save me that step. Slick little device for $20 that's for sure. Now I just need my installer to get here!I just installed one of these. A bit less expensive than what you linked, and it has two ports, which you might not need but I did. Set it in "Client" mode, and it connects to the Wifi network and allows hardwired connections. Not too hard to set up, it will even search for available SSID's and list them by MAC Address. It was helpful for me because I have two access points with the same SSID and wanted to make sure it was connecting to the right one.Leave a comment:
Wireless sma
Hi just been u there and there's a double socket and one if the sockets has the TV aerial plugged in and the other is spair but it's halfway along the loft
Would I just need a longer Ethernet cable
Thanks for the help
ChrisLeave a comment:
Wireless sma
Thanks for the help
You won't be able to get power for the wifi device over the ethernet cable. However, installing a local power outlet by tapping the AC connection to the inverter would work, just make sure the tap is protected with low current fuses.Leave a comment:
Tp link sma sunny boy 3600tl
Hi guys I have the above with a webconnect thing built in but don't fancy a wire coming from lift so seams a good solution but I don't have a mains power in lôft will this still work ie power from inverter to tp link via Ethernet (short) wireDepends on the location of inverter and router. My inverter locate in the garage where wifi signal is really low. I could have use what sensij suggest but buy 2 of them (one for client and other as repeater for range extension) but installer supply me with powerline adapter instead.
http://www.amazon.com/TP-LINK-TL-PA4...0285008&sr=1-1
Any help grate lily received chrisLeave a comment:
http://www.amazon.com/TP-LINK-TL-PA4...0285008&sr=1-1Leave a comment:
No, with a SolarEdge inverter. It doesn't matter though, it is equivalent to plugging directly into your router.Leave a comment:
