i have 4 12v panels that need to be wired series parallel to output 24v! Im using S.O. cable with red and black wires. I need a detailed wiring diagram on how to do this. Can anyone help?
Most Popular Content
Need help. Wiring 4 12v panels to output 24v
What are you charging, and what kind of controller are you using ?
panels "labeled 12V" generally put out 19-20V to be able to recharge a 12V battery 2 in series gives close to 38V, for charging a 24V batteryPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Is this going to be a 24V battery bank or a 12V bank ?
What is that charge controller PWM, MPPT ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Provided the panels have MC-4 connectors in the output cables you series connect two at a time, then use a parallel branch connector. From there you can buy a length of pv wire with male and female MC-4 ends and cut it in half to continue on to your switch gear.
parallel connectors.jpg2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
OK, so you need a simple 2S2P PV array.
wire 2 panels in series, and then the other 2 in series
then take the 2 pairs, and wire in parallel
scroll down to Solar Panel Wiring Diagram #3: shows 4 panels , 2S2PPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I use this type of PV setup for greenhouse lighting system is this your set-up if so I soldered and shrink wrapped my cables
