I have three strings, 1 volatage 384, 2 390, 3 zero. My amps measure 1 7.5, 2 7.8, 3 8.4. what is wrong with my third string?
Most Popular Content
String voltage
Thanks you are absolutely right. These are questions ask by Nabcep which for me your answer is the no brainier but their answer bank wasn't that simple. So just picking people's brain. Thanks. Why would it register the higher amps. I would love to pick your brain with questions if you don't mindComment
in a PV panel. Isc is larger than ImpPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That is crucial information you withheld and is the smoking gun. So I got it right with you having a wiring issue, and now that I know 0 volts and high current means it can only be one thing. That string is shorted out as others have stated after you let it be know there was high current.
No Voltage + No Current = Open Circuit
No Voltage + High Current = Short Circuit.
Read the question carefully because the full question tells you the answer.
