Hi, I just got back from staying with my daughter and son-in-law in northern Europe (latitude about 57 degrees). They live on 3 acres surrounded by forest, and currently have a 1 panel, 1 battery temporary system. Connecting to the grid might cost about $15,000. Given the latitude, the low sun in the winter, and the trees blocking the low sun, they will probably need a 1-2 kw solar system (placed at the north end of the property facing south) in order to generate enough for lights, cell phone charging, and maybe some water pumping when the sun is lowest. That brings up the question what to do with the extra electricity during the rest of the year. I have seen some tables suggesting that the ratio of sun max (longest day)/min (shortest day) at their latitude is about 30, without accounting for the trees blocking the low sun. Their ratio might be 40-50. I suggested getting (maybe in a few years) an electric car. In the winter, the car can be charged somewhere else on grid, and the rest of the year, some or all of the car's charging can come from solar.
I haven't seen much of anything about how to design a solar system with that in mind. Other than for the car, probably they need only a few kwh battery capacity. Ideally, you could plug in the car and charge from both the panels and batteries, but not discharge the batteries below a certain point to reserve enough battery power for the critical uses. Also, as the car battery is so much bigger, it can be charged much faster than the solar battery pack can be discharged without reducing the lifespan of the solar batteries, as I understand it. Is this kind of application supported by existing equipment, or would they have to manually (with a switch) disconnect the solar panels from the battery/house system and connect them to the car when the car was charging? Any other ideas about 100% off grid systems in such northern conditions with the low sun being blocked? The forest also blocks the wind, and there are no streams through their property.
Thanks.
Thanks.
