Shout out to all the Cali Members
    • 15016
    Originally posted by M j hodgson
    I have got 4 panels now needing new tedlar backing have bought tedlar with insulted backing how do I put it on please Michael
    The insulated backing will cause the cell operating temp. to increase. That will decrease a panel's output.
    Do not use any insulating material on a PV panel.
    What you bought is not a good idea to use. Do not use it for panel backing.
    Do not use Tedlar with insulted backing. You will not only decrease the array's output, but if the insulation's effect is great enough, you may harm the panels or at least decrease their service life by increasing the cell/panel operating temp.
    Also, whatever you use, get it tight to the back of the panel. Not doing so will leave an air gap that will also act as an insulating layer behind the panel, the effect of which is roughly the same as the effect of using single vs. double glazed windows on the heat loss of a window assembly. It will increase the panel temp.
    For that matter, why do you need to replace the backing at all ? What happened that makes that necessary. Seems unusual. Just curious.
    Also, this may be better handled in a new thread.
    Be careful.
      You use what is called a vacuum laminater. Lay the panel face down, a sheet of EVA adhesive, and then your tedlar film, squeegee out all wrinkles, and start the lamination cycle. it will pull a vacuum, start the heating, and in 30 min, be done. No way that i know of to do it by hand.
      Read this post and the links for how to DIY.
      Do you really want to build your own solar panels? Discuss, share ideas, and get questions answered in this DIY solar panel forum.
      • M j hodgson
        • Dec 2018
        In view of my last post bought tedlar sheeting with eva to back four panels do I put eva to the panel first or tedlar side thanks still on learn curve.
