Announcement
No announcement yet.
Well pump and req'd accessories
  • Filter
  • Well pump and req'd accessories
    Hey,
    I have a friend who wants to put in a solar powered backup in case his power goes out so he can run his well. I was thinking of putting in enough batteries to start and run the thing (at 21 volts and 9.8 max amps), and am wondering what kind of set up would be most cost effective? I was thinking a few solar panels (4 panels for around 800 watts) and then just running a charge controller and a battery bank that would tie directly into the pump's electric system. I would also put in a DC disconnect and mounting brackets for all of the batteries to be at spec for NEIS, but is there anything else anyone can think of that I would need to make it work? The panels would charge the batteries as needed all day, and because the pump doesn't stay on all the time I am hoping the battery life will do for this application. Any advice would be greatly appreciated. Thanks in advance!
  • #2
    a 21V 9.8a pump is very oddd.
    Sure it's not a 210V AC, 9.8 amps ?
    • #3
      oops
      Yep, you're right, 210 V AC, which means I need an inverter and an AC disconnect too.
      • #4
        2 Kw AC motor is going to be very expensive to run on solar.
        • #5
          That's what I thought. Somewhere in the 10,000 dollar range, no?
          • #6
            You need to find out first:
            Required LIFT of the water
            Required GPM
            Required run time per day.
            This will be a LOT easier if pumping to an elevated tank, and would be very expensive if he has a pressure tank, where the pump cycles ON OFF while water is being used.
            Maybe a $600, 5,500W genset is the better way to manage this for short emergencies, solar, batteries and inverter to run a pump this size is going to VERY expensive.
            • #7
              thanks
              Although I was hoping to do a solar installation, the genset is definitely the way to go. Thanks a lot for the recommendation, and I am sure my friend would pass along his thanks as well.
              • #8
                It might not be the case, but I am planning this for the near future:
                - A "Rule 1500" 12v/5A (marine bilge pump) * or an alternate model**
                - one 130W or 200W PV panel
                - controller to lower the panel to 12v (might choose an 24v pump)
                The pump will operate during the day and rest at night, that's why I didn't add batteries to my plan...
                In my case the height difference between the river and the artificial lake is only 2m. I guess these pumps (Rule models) flow a good amount of water but are supposed to have a lower column of water on the exit... the Shurflo models are better for higher height differences...
                __________________________________________________ ___________
                - low pressure, high flow -
                *Rule pump specs:
                Flow Rate: [COLOR="#FF0000"]1500 (gph)[/COLOR] or 5678 (lph)
                Port Type 1 1/8" (28mm) Hose barb
                Voltage 12 or 24 (Vdc)
                - higher pressure, lower flow -
                **Alternate pump: Shurflo 12v/9A - Specs:
                Name : Shurflo Extreme Smart Sensor 4.0
                Model NumbersOEM/Aftermarket : 4901-0201, 4901-0211
                Voltage : 12 VDC
                Dimensions Inches/Millimeters : 8.3" x 5.3" x 5.0" [210x136x127mm]
                Flow Rate GPM/LPM : 4.0 GPM ([COLOR="#FF0000"]240gph[/COLOR]) [15.1 LPM] (60.4LPH)
                Amps (Max.) : 9
                Shut-Off Pressure : 50 PSI [3.4 BAR]
                Rod - Brazil
                • #9
                  where to get the genset?
                  So an earlier post mentioned getting a genset, and so I wondering where I can find one for that amount? Thanks in advance!
                  edit: so I googled 5500w genset and found a few. Does anyone have a brand recommendation?
                  • #10
                    Well, this is for emergency (4 days a year? ) use, not daily, correct ?
                    A google search for generator sales turns up a boatload of sites, with many choices of generators in the 5,000w ballpark.
                    There is so much variation between needs, it's hard to guess what's right for your use.
                    • #11
                      Genset
                      If you are mechanically inclined, you can get an older onan out of a motorhome. They are great generators. I have 3 of them. The twins generally run at lower rpm (1800 vs. 3600) than the disposable units available today. There is a blog called smok stak where you can get a lot of info. With a little patience you can find them cheap on ebay or craigslist or your local wrecking yard.
                      http://www.smokstak.com/forum/forumdisplay.php?f=1
                      If you want a new dependable generator, buy a Honda. But they are expensive.
                      • #12
                        Yep, just when the power goes out. Thanks for searching, I'll just go with a good name brand.
