Actually if you use the right kind of DC motor you do not need a converter.
Solar Water pumping design
But the question remains where does he propose to get the DC from at any voltage if he doesnt want to use batteries ?Comment
Mike you just mabe be right, I have no better answer anyway,, .. mabe or resident electrical engineer Sunking has a answer we have not thought of.??Comment
well your dc to dc converter will be converting from whatever you are powering it from?? To 24v dc nominal .. Some dc to dc converters give very accurate outputs some dont. In your case if it varies betwen 22 and 26 it will not effect a pump motor.
I still dont see how you are not going to be using batteries on the input side of the dc to dc converter, ?????where you going to get the higher? Dc input voltage from for the converter if not from batteries??/
I just want to know, the amount of voltage that can be boosted by a dc-dc converter.?Comment
There is no limit to the voltage a DC to DC converter can do ie 6000 to 6 or 6 to 6000
You cant run a DC to DC converter directly off the solar panels. One reason the voltage would never be constant enough.You have to use batteries and a solar battery charger. there is no other way.
Finding a DC to DC converter that can do 3 phase is going to be tricky to say the least.
In the requirements it states you are to use a nominal 24v motor, Why you not just using that as asked?Comment
