Hey guys, my pond doesnt get much sun in the winter but about 6 feet away is a tall pole that gets direct sun most of the time. I am in CT. I want to use my pond aireator to help keep a small hole open in the ice most of the time. Is it possible to do this with some kind of solar and battery kit? I know it would probably be cheaper to just run a wire but if it can be done for my small little device with solar I'd rather do it that way so I don't have to trench in a wire.
6w aireator
Thanks for the spec info, that's what I need because I don't have the knowledge to know what to buy on my own. Is it safe to use a solar panel with a pond or is there much risk of turning myself into Frankenstein? I also wonder do I need some kind of special housing to keep the battery outside and will the battery be huge like 50+ lbs?Comment
The battery should be in some type of weather proof box. They sell those boxes on Amazon or at a local boat or auto shop. The battery may weigh about 30 lbs depending on what you get.Thanks for the spec info, that's what I need because I don't have the knowledge to know what to buy on my own. Is it safe to use a solar panel with a pond or is there much risk of turning myself into Frankenstein? I also wonder do I need some kind of special housing to keep the battery outside and will the battery be huge like 50+ lbs?
The voltage put out by the panel and charger would be below 50V DC so it is relatively safe. While a battery is only 12V you can cause an issue if you short the positive and negative terminals together. The result is the battery tries to discharge it's entire contents all at once which can result in sparks and a fire so be careful.Comment
I see, kind of like when you're jumping a car and someone touches the two ends of the jumper together and it sends sparks out?Comment
A short circuit in a FLA battery, causes the battery to heat from internal resistance, boil the electrolyte in a couple seconds, and then an acid steam explosion, giving things a good hot acid wash. Not fun.
A battery being charged, generates a bit of hydrogen gas, and a spark can light off a cell, and then you have a hydrogen explosion, but not quite as much hot acid spray.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Is the explosion from a 30lb battery like something huge or only hurts you if you're within a couple feet of it? I'd like to use solar/battery but it sounds kind of riskyComment
If you are holding the cables, you are likely right on top of the battery if it goes boom. If you follow reasonable safety procedures, you don't get a battery explosion. But if you start your day with " Hold my beer, watch this" be careful.While a battery is only 12V you can cause an issue if you short the positive and negative terminals together. The result is the battery tries to discharge it's entire contents all at once which can result in sparks and a fire
We are just pointing out risks involved. The risks can be reduced to nearly zero with a little bit of caution. There's thousands of ranchers with 12V car batteries & solar, running fence chargers in the middle of nowhere that never start fires.
