Thanks for your reply. I saw a youtube whereby a guy claims he can rum an ac pump 75watt with an 300watt inverter and a 7Ah battery. If this is not a hoax its ideal for me.
Inverter to Battery
If you have wired your system so that your battery is being charged via solar panels and a charge controller and the battery is also be used by the inverter for your loads you should be ok.
Your battery will provide power to your loads and can still be charged by your solar panels. For that matter if your battery is "technically full charged" then your loads will get powered from your solar panels through the CC , battery and inverter.
Now if your loads drain the battery then all the charging amps that are generated by your solar panels will go into keeping the battery from dying.Leave a comment:
Inverter to Battery
If i connect my inverter directly to battery and i have load during the day when the battery is also charged what happend??
will the battery also be charged when there is a load??
