It depends on the pump motor and controller specs. That picture does not provide details as to what each component is and how it is wired. It also doesn't tell you how long and how much water it pumps.
I do see about 40 solar panels which probably total about 10kw.
AC waterpump with solar panels
As i mentioned earlier i saw at so many places Ac water pumps running directly from solar panels without battery. Recently I've visited one place where they newly fixed this system and it was running properly without battery. They are using Solarpanels, (special) waterpump controller/inverter that's it.Attached FilesLeave a comment:
hobertek is history - posting from Sacramento - maybe it was governor moonbeam incognito?Leave a comment:
I was commenting on; inverter power = ac pump power which is not true. More like 2 x inverter power = AC pump power depending on the type of pump starter.
Also solar panel = 1.5 * AC pump power for maybe a couple of hours on a really sunny day, then as the sun energy goes down the pump will slow down and burn up if not cooled.
You are underestimating the solar equipment needed to run a 40hp motor long enough to pump the amount of water the OP wants.Leave a comment:
ac pump +inverter+solar panel
Hello,
I'm planning to run AC submersible pumps with solar panels at some places.
I want to run all of them in daytime without any battery backup.
Some of them AC 220 and 380V.
But I have no idea how to calculate and make connections of solarpanels in order to run directly in daytime.
Thank you
inverter power =ac pump power ,solar panel =1.5 *ac pump power , it can work perfectLeave a comment:
Great. While you are researching that site get "all" the data and specifications of the equipment needed to run an AC motor using DC panels. I will bet there is some type of battery or energy storage system in that "inverter box".
Based on my 40 years of electrical experience AC motors do not run well on a variable voltage supply while DC motors work relatively well that way.Leave a comment:
I will upload a video of AC water pump running directly from solar panels when next time I will visit that placeLeave a comment:
Link removed - you are trying to get cheap advertising for BS maybe?I have seen at so many places running AC submersible Pump (single phase/three phase) running directly from solar panel without battery.
I am sure about it that AC Pumps can be run directly without battery (because I have seen at 5 or 6 places if im not wrong) but I have no idea how to calculate which inverter and how many panels it require..
They use these kind of controller/inverter.Leave a comment:
