The maximum power horses !
A 60 HP pump is quite an awesome beast. There are not likely very many of them around. The power required to run it would be at least 50KW. So, it's a bold claim, and we often hear tall tails here, so a photo, or site details would give your statement some credence.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
And I want to see how you manage without MPPT. Bruce RoeOriginally posted by stubbyboyi currently run a 60 hp water pump using solar dc no inverter or mppt works great so farComment
How much 5 Hp DC motor give flow of water in gallons per minute
i want to pump water from 100 feet.Which DC motor would be feasible?Comment
Grundfos makes DC well pumps that work quite well with solar.
What is more important is how much pump do you need.
What are the minimum daily or hourly gallon or liter requirements?
What is the size of the well casing.
You are in Israel If I read your other post correctly So I would imagine pretty sunny.NABCEP certified Technical Sales Professional
Here is my requirement for solar power pump system
I am from pakistan and want to install this sysyem in villages. My requirement is to use 5HP DC motor along with 5kw panels. I want to pump water from 100 feet and minimum daily requirement is 0.5 cusecs and want to use this system 5-6 hours per days.
Kindly guide me about this.
ThanxComment
