My old mower croaked, my neighbor gave me this one (also with blown engine), and I had an electric gokart that my son has grown out of - so.....
New Lawnmower!
I'm just tired of these unreliable ICE engines.....BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
Will see how tired you really are when it can cost you $5000 to replace that $1000 engine with Motor, Batteries, and Controller. You could buy a brand new JD Lawn Tractor for less than it is going to cost you for something that does not work as good.
I take it this is a riding Lawn Mower? That will require some challenges because of the Low RPM nature of the design. Most riding mower motors operate at 3600 RPM. I know a few folks who have done this and I helped them out. Most work with High Torque OEM Golf Cart Motors, Controllers, and AGM batteries. Or if you can afford a $2500 battery lithium.
However this is the WRONG FORUM to get any meaningful help Try DIY EV
Two options on motors. D&D Motors if you go the DC motor route, or HPEV for AC motor. Most likely because of the Low RPM nature and budget you will go with a 48 volt Series Wound DC motor. Just besure to do your homework because the 48 volt DC motors come in two flavors: Speed and Torque, you want Torque, something where peak power band is at 3000 to 3600 RPM's
You can get a good 48 volt DC Series Wound motor for $600, another $500 for a 650 amp controller, and another $600 for cheap 2-year batteries. Or if you want AC you can get a 16 Hp/80 HP peak with 550 Amp Controller for $2400, plus another $2500 for a 48 volt 100 AH lithium battery.Last edited by Sunking; 08-29-2016, 11:15 AM.MSEE, PEComment
I already had the all the stuff except the three batteries. Had to spend a couple hours machining (doesn't everyone have a machine shop?) an adapter to the pulleys. Works great. Very powerful and quiet - and so nice to just get on flip the switch and go - no swearing at the engine to get it to start....
I moved from 1/2 acre (zoned AG) near work, to 5 acres (zoned AG) 100 miles away. Unlike most of IL, the terrain is hilly enough to
make AWD necessary for mowing and snow blowing (480' of drive + 1000' of paths to buildings & PV array). The smallest tractor
with AWD and PTO drive is a Simplicity Legacy, which does come with a cup holder and cruise control (I use neither), and power
steering. A cab can be used for snow blowing, but the job is done so quickly its hardly worth the trouble. Bruce RoeLast edited by bcroe; 08-29-2016, 12:00 PM.Comment
From someone who once lived in a 100 + "/yr. snow climate, understood.
J.P.M.Comment
