I currently live in a camper that receives about 7 hours of sunlight a day. I set up four batteries in a parallel bank and have two 100 watt solar panels in direct sun. I also have a solar charger in between the solar panels and batteries and a 5000 watt 10000 peak inverter.
Currently I am trying to run AT LEAST my camper air conditioner, an iphone charger and a laptop charger; as well as my fridge.
4 batteries = 400 AH
2 solar panels = 200 Watts
Air Conditioner uses 20 Amps to start and 16 to run (Which I only need for 4 hours a day.)
Fridge takes 25 Amps for 6 hours a day.
Laptop charger takes 4 amps for 8 hours.
Iphone charger takes 3 amps for 8 hours.
Now...my current problem is the fact that when I turn off AND unplug every other device all except for my air conditioner, even after a full day of sun it will try to start and then the inverter will kick off and I hear a very long beep until I turn the inverter off. Also, after I tried the air conditioner my inverter kicked off after about 20 minutes of use with just a regular house fan.
Images of setup below:
http://imgur.com/a/pg2gb
