Solar powered AC air conditioning, a bummer or a challenge?
In Vegas street cafes use them - an umbrella of the fine mist.
Here they do help
On an industrial basis the dry fog is used for dust suppression in material handling systems. The water droplets are fine enough that you can run your hand through the mist and it comes out dry - hene "dry fog".
It is a high pressure system with special nozzles but nothing exotic.[SIGPIC][/SIGPIC]Comment
The big problem with the peltier module, is only a 40F difference from the hot to the cold side. Second, is the waste heat that has to be discharged from the hot side. About 70% of the power consumed is simply converted into heat, and only a small amount of heat can be pumped from the cold side.
Then you also have to discharge the condensate water that will collect on the cold side.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Alan, my point was that the air conditioner you built had a power consumed to btu ratio that was 3-4 times higher than a window unit. I don't see how you can run that entire ship with so little cooling power.Comment
What you think he claims is completely false, and was the point of my intervention. A window shaker is 4 times more efficient than any Peltier unit.MSEE, PEComment
No room for misguided enthusiasm on this forum.
I wonder if a truck/van air conditioner could be a solution for small rooms. There wouldn't be any inverter efficiency loss in that scenario. Nor would there be the inflated cost of a home DC air conditioner....
Thoughts anyone???Comment
Nice idea but most vehicle air conditioners use the engine to run the compressor not the battery or alternator.No room for misguided enthusiasm on this forum.
Thoughts anyone???
My RV has two roof top units but they will only work when I have the generator running or I am plugged into a grid connection. They are just too big to run off the coach batteries.Comment
What about passive cooling? You don't to go down very far before the ground temp drops down to around 50 degrees. Did a trench, lay tubing and pump water through it to a exchanger in the shack with a fan behind it. 50 degrees isn't exactly cold but it is cool enough that it would keep the temperature in the room down.Comment
Sorry Jim but that is a green myth - to get the heat transfer it would take a very long tunnel plus the 50° is an old wives tale. You also end up with a real potential for a mould problem - nasty!What about passive cooling? You don't to go down very far before the ground temp drops down to around 50 degrees. Did a trench, lay tubing and pump water through it to a exchanger in the shack with a fan behind it. 50 degrees isn't exactly cold but it is cool enough that it would keep the temperature in the room down.[SIGPIC][/SIGPIC]Comment
Earth tubes can work well in good environments (i.e. cold earth) but don't work well in southern climates where the ground is warmer year-round. As with any cooling system you have to be careful with condensate management; if the water is allowed to sit in the tube you get mold and other problems. They also take up a lot of space. You need hundreds of feet of tubing to get good coupling to the earth.What about passive cooling? You don't to go down very far before the ground temp drops down to around 50 degrees. Did a trench, lay tubing and pump water through it to a exchanger in the shack with a fan behind it. 50 degrees isn't exactly cold but it is cool enough that it would keep the temperature in the room down.
But if you can manage all that you can get very cheap cooling, at least on days that aren't _too_ hot.Comment
Earth tubes can work well in good environments (i.e. cold earth) Please name a few places
but don't work well in southern climates where the ground is warmer year-round. Ground temps don't vary like that
As with any cooling system you have to be careful with condensate management; if the water is allowed to sit in the tube you get mold and other problems. How do you prevent the condensation?
They also take up a lot of space. You need hundreds of feet of tubing to get good coupling to the earth. At least that I can agree with
If frogs had wings they wouldn't skin their butt hopping. It is an idea flogged on green sites from time to time but not worth the problems plus a rather large volume of air is required.[SIGPIC][/SIGPIC]Comment
No sir the AC power comes from the engine. Now there are DC air conditioners made for Tractor Trailers and trains that use 24, 48, and 96 volt DC, but again the power is coming from the alternators.
Only way remotely possible is with DC powered Split Air Conditioning. There are quite a few out there. Marv Air makes one for Marine environments in 12 and 24 volts with 5000 and 7000 BTU models. The 5000 BTU 12 volt units pulls 400 watts and one of the least expensive at $4000.MSEE, PEComment
There is a growing market for DC A/C for tractor trailers that can run off battery while the engine is shut off because of idling restrictions. In those cases efficient operation with minimal battery drain is a selling point. But the recharge of the batteries ultimately comes from the main engine alternator or from a small quiet auxiliary generator.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Earth tubes, we called it ground cooling when I was in school for HVAC in the late 70's. We built homes with extremely low heating and cooling bills. People just didn't seem to like having their homes half buried in the ground and dealing with the limitations and maintenance of the systems. They only accept those things if there is really no other choice. Back then it was the embargo, today it's the environment driving it. Nothing has changed though, if it isn't plug in and turn on, it's a compromise.
As far as mold goes, you probably have some in your air conditioner but that's nothing compared to the average swamp cooler. Along with their limitations they can be nasty after not being run for a while.Comment
Mould can grow anywhere true - a few hundred meters of dark and cool earth tube is a heck of a lot more problematic than an AC or swamp cooler that can be cleaned.People just didn't seem to like having their homes half buried in the ground and dealing with the limitations and maintenance of the systems. Don't confuse a home built underground with earth tubes meaning tubes/tunnels that air can be drafted through. The underground home concept is valid. It takes advantage of low swings in ground temperature as compared to the atmospheric temperature swings.
As far as mold goes, you probably have some in your air conditioner but that's nothing compared to the average swamp cooler. Along with their limitations they can be nasty after not being run for a while.[SIGPIC][/SIGPIC]Comment
