PN you know I am a fan of Anderson Connectors, good stuff. But to all using them, never ever add any solder to any compression connector. All that does is add resistance and weakens the connection. Every code making authority either limits or forbids any soldered connections. Examples SAE (Automotive), ABYC (Marine), FAA (Aircraft) all forbid soldered connections, and NEC (Home-Buildings-Industrial) allow solder providing the solder is not used or relied upon for electrical or mechanical connection.
MC4 Connectors SUCK for off-grid systems!!!
Well, it's hard to argue first hand results. 8 years is way beyond the warranty & design of golf cart batteries, usually a 1 yr warranty, and with good care you get 4 years from them.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
