Will 5 12V 100W panels in parallel work with a 24V controller?
Charge Controller Question: Uneven number of modules in series strings
I would find another 315 watt panel and go with 3s2p into a Midnite Classic 200. As to having the odd single panel on its own controller that wont do anything being that it is a 24 volt panel trying to charge a 48 volt bank/2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Unfortunately even if you wire a number of those 12v panels in parallel they will still not generate the voltage needed to charge a 24v battery system. You need over 32vDC which you can get by wiring 2 of those 12v panels in series.
Just for your knowledge that while they are "labeled" 12v they actually produce closer to 18v where 2 in series will produce 35 to 36 volts.Comment
