Running a chest freezer as a chest refrigerator on a trailer
OK.....got the problem now. I thought this was more of a "keep the food cool while in transit" kinda thing.
In that case, I'd rig up a couple batteries and the charger on some kind of moving dolly, permanently like......then wheel them out of the trailer after you park it, and into whatever truck you used to park the trailer. Take the "power pack" we'll call it, home with you, and keep it charged, then take it to the trailer the night before to power the fridge/freezer. Not as convenient as setting up the whole thing permanent in the trailer, but cheaper.
Your alternative ( and maybe this is starting to look more attractive now ) is probably 300-400w of panels mounted permanently on the roof of the trailer, and a charge controller to the battery bank. That would probably amount to about a thousand bucks, plus you would have to make sure the trailer was parked in an area that got decent sun while parked. Also, in that case, I'd probably go with a sealed, no maintenance, AGM type battery so you didn't have to worry about flooded cells drying out on your unobserved.
I might be back to Mike's suggestion.....drop a block of dry ice in their the night before.Comment
Thanks! This whole thread and forum has been very informative - I really appreciate the input. The dry ice plan is really starting to look good - I hate to swing another grand right now (trailer is being built...) if I don't have to. The power pack on a dolly is 'just about' what I had envisioned when I first thought about this issue and then I thought about solar recharging...considering my trailer lot is like 5 min away from the house, it's not a huge deal to take the power pack over. But the dry ice would be easy too - lol!OK.....got the problem now. I thought this was more of a "keep the food cool while in transit" kinda thing.
Thanks to everyone for their input - much much appreciated!!Comment
Actually, get a cardboard box, that will elevate the dry ice to just below the top of the chest. Set the paper wrapped block on that, the cold air will settle and chill from the bottom up.drop a block of dry ice in their the night before
If you drop it at the bottom, it may dent the case (dry ice is really dense and heavy) and it will take longer to chill, with the dry ice setting in the cold spot.
about $15 for 10 lb block . Much less than solar/inverter/batteries, if you have a source of dry ice around.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks!! I found a local supplier close by - just have to check cost when they open tomorrow. I think this will be a good solution to the problem.Actually, get a cardboard box, that will elevate the dry ice to just below the top of the chest. Set the paper wrapped block on that, the cold air will settle and chill from the bottom up.
about $15 for 10 lb block . Much less than solar/inverter/batteries, if you have a source of dry ice around.Comment
