Has anyone had experience with Goal Zero (Goal0) portable systems? I am thinking of buying a $500system (30 watt panel) and battery supplying supposedly 350 watts. Add-ons seems extremely expensive: another 30-watt panel for $300 and another battery (supply another 350 watts) for $300. Any other suppliers similar? Goal Zero seems to get good reviews. My idea is to buy another supplier's panels and/or batteries to the system but do not know how feasible (and might void warranty?)
Goal zero portable systems
You need to tell what your goal is for anyone to make useful comments. With what information has been supplied Sunking is 100% correct.[SIGPIC][/SIGPIC]Comment
Movers dolly/hand truck, milk crate and zip ties. A good start for building your own, while getting more, and sending less.
And there is this idea, of my Monolith
not as portable.
Photo is of what I call, my Solar Monolith. (How-To) A group of us bought several Unisolar 64 panels back in 2001, as part of the Alternative Energy Zone Village at Burning Man. I wanted to make a self-contained "box" that was portable [ha!] and did not drag a bunch of wires around. Well, it's all in one box, and fairly neat, but with a full sheet of plywood, and a couple of deep cycle batteries, it's barely lug-able (photo of innards) . I used Mayor Roger's idea of a 4" PVC pipe as a roller, to load and unload from my truck. It's been to several fairs, and many trips to the Playa .
Mono_2005_CS_056.JPGPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
not as portable.
Photo is of what I call, my Solar Monolith. (How-To) A group of us bought several Unisolar 64 panels back in 2001, as part of the Alternative Energy Zone Village at Burning Man. I wanted to make a self-contained "box" that was portable [ha!] and did not drag a bunch of wires around. Well, it's all in one box, and fairly neat, but with a full sheet of plywood, and a couple of deep cycle batteries, it's barely lug-able . I used Mayor Roger's idea of a 4" PVC pipe as a roller, to load and unload from my truck. It's been to several fairs, and many trips to the Playa .
(photo of innards)
Mono_2005_CS_061.JPGPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
