The top two wires are empty.
The bottom red and black shoulf go through the wall to the respective batttery + and - terminals. This reads voltage.
The Middle two get routed to the shunt. THe blue wire gets connected to the part of the shunt that is closest to the battery. The yellow wire gets connected to the opposite terminal of the shunt. This reads amps.
With no loads on, the battery monitor should be pretty close to what the solar panel is putting out for charging amps. If the SOC is staying at 100% all the time, may be that the amp cables (blue and yellow) are backwards. Needs a negative amps to go below 100%. Kind of hard o tell from the pic, but appears yellow and blue may be reversed at the shunt. If this is true, charging with the solar panel will read a negative amperage.
You will need to adjust the monitor to the correct size in AH for the battery you have for the SOC tone accurate.
