i suspect your charge controller is not a true MPPT controller. You typed MPP, which is close enough for a sales scam/pitch, but it won't downconvert your 41V to 30V for charging. Measure your Amps in from the solar, vs the Amps out from the controller to the batteries, (without any loads on)
> 6 flex panels, 160w each, 22.8 voc, 8.6 amps per panel.
> Wired 3 groups of 2 in series parallel for a desired total of 41v and ~25amps.
4 panels wires 2S2P would produce a mess. 22.8Voc is not a usable power measurement, We need the Vmp voltage, which I will guess is about 18V
160W @ 8.6A = 18.6Vmp
With panels , voltage is easily achieved, and as sun gets stronger, the amps increase. in real life, you can expect to harvest only about 80% of the panel nameplate rating.
160 x 4 = 640w / 80% = 512watts @ 37.2V = 14 amps. A true MPPT controller will increase those amps a bit, as it matches the charging voltage of the batteries around 30V
