High battery voltage
  • john.b
    • Oct 2017
    • 43
    Hi, i've just built a solar tracker as an experiment and have powered the two actuators with a 7ah sealed battery (NP7-12) the type you find as a backup in security alarms, i bought a small 20w solar panel that moves with the tracker to keep this battery charged. both panel and battery are new.
    We have bright sun here today and i've noticed the battery voltage is sitting at 17.30v. is this to high ? is it going to kill the battery? or is it with in a safe limit.
    Thanks
    john
    That is way high for a 12v battery. Do you use a charge controller, or is the panel wired directly to the battery ?
    Your battery is a bit undersized for that size panel, 12v 10ah would be a better match to the panel and not be charging the battery so hard
      • 15186
      Thanks
      john
      John. If you have connected the panel directly to the battery you will end up cooking it. That is why a Charge Control (even a cheap one) is something you need to control both the voltage and charging amps to a battery.
      • john.b
        • Oct 2017
        • 43
        Hi Guys, thanks for getting back, the panel is connected direct to the battery without charge controller, the panel had two alligator clips for direct connection so i just assumed it would be regulated, that said i think it's for a car as it also come with a cigarette lighter type connection so maybe for a bigger battery, i have a PWM charge controller so will try that tomorrow.
        Thanks again
        Take care
        john
          • 15186
          Thanks again
          Take care
          john
          Keep us informed on how you make out with the CC.
          • john.b
            • Oct 2017
            • 43
            Sorry you will have to forgive me i'm quite new to solar, CC ??
            • john.b
              • Oct 2017
              • 43
              Ah penny just dropped Charge Controller,
              • Yet another Yeti
                • Feb 2019
                • 51
                The forum software clips many special characters .
                Try again with typing full names .
                • john.b
                  • Oct 2017
                  • 43
                  Hi, just a quick update on the battery voltage after using the PMA charge controller, over the last few days it's been quite overcast and the voltage has been sitting around 12.8v today was real sunny and the voltage hit 14.2v at best so i'd think that's now in the save zone.
                  Thank you all again for your help much appreciated
                  Take care
                  john
