solar system for shed
    Originally posted by Freeesun
    ..... but there's a video on YouTube that shows that they are both very similar in there outputs when compared side by side......
    I saw a video on youtube that proves absolutely nothing. And then it was over. If you want it, you can find it on youtube. But its not often right
    • Freeesun
      • Oct 2018
      • 144
      #107
      If I go down to 10 gauge I would have to use a different fuse type and not use in line. Maybe I should use the car audio fuses they use under the hood of cars.
      all the in line ones I see are 16 gauge and I somehow found a 14 gauge.
      12v 150watt, 80ah battery, 75 watt inverter.
      • Freeesun
        • Oct 2018
        • 144
        #108
        What fuse size should I use for my battery to my fuse box? I don't have a inverter anymore.
          Fuse size depends on the wire size you chose. Small wire needs small fuse, large wire can use larger fuse. Fuse prevents the wire from melting and starting a fire
          links below are designed for boats which have strict standards, and should be applicable to many DC solar installs
          https://www.bluesea.com/resources/1437
          https://www.bluesea.com/support/arti...t_Installation
          • Freeesun
            • Oct 2018
            • 144
            #110
            thank you very much
            • Freeesun
              • Oct 2018
              • 144
              #111
              anybody have any suggestions on 12v lighting? any manufactures that i should be looking at? preferably on amazon canada.
                Look at RV centers, the campers are all converting to LED lighting, you will find best selection of 12v LED's and fixtures there.
                • Tecnodave
                  • Mar 2019
                  • 150
                  #113
                  LED Lighting on the dirt cheap........check out the "COB LED" boards on Amazon, (chip on board) these are arrays of led's on a pcb, 12 volt and small enough to glue into existing fixtures, they are 10 times or more efficient than incadensent bulbs. Some do not last too long but most will last several years at a couple of bucks each, they pay for themselves in short time due to the effeciency, not using excess solar power. These are bare boards and do not come with a fixture but fixtures are cheep, they can be repurposed
                  • Freeesun
                    • Oct 2018
                    • 144
                    #114
                    Single conductor copper wire or cca? Similar price on amazon. Both 10 gauge. All I need is wire and terminal and I'm all set to start harvesting
                    • Freeesun
                      • Oct 2018
                      • 144
                      #115
                      I will defiantly look into those lights I seen some that fit regular house light fixtures so I was considering those too but we'll see after a little more research.
                        • 5243
                        #116
                        I am tired of stuff that lasts several years. I want to optimize a project, then go on to
                        something else, not spend the rest of my life fixing it over and over. I HATE STUFF
                        THAT BREAKS. Of course my Cleveland friend says, THE MORE STUFF YOU HAVE,
                        THE HARDER IT IS TO KEEP IT ALL WORKING. Bruce Roe
                        • littleharbor
                          • Jan 2016
                          • 1998
                          #117
                          There's tons of 12 volt led lights available for every imaginable RV light base configuration made. I cant imagine having to modify a board to fit your existing fixtures. Check eBay first for RV replacement led lights.
                          • Tecnodave
                            • Mar 2019
                            • 150
                            #118
                            @bcroe,
                            That is exactly most of my solar gear is MidNite and the rest is from MMMOES.......MidNite,Mstar, MagnaSine,Outback.Exeltech, Schnieder, no cheep Chinese stuff where it counts! I do experiment a lot to find what works. Good 12 volt LED fixtures are not inexpensive, I can build one for <$10.00, better looking and brighter than what's available. A failed led string on a chip board is not a crisis! I use 6-12 chip boards in a 14" light fixture.
                            • Tecnodave
                              • Mar 2019
                              • 150
                              #119
                              @littleharbor,
                              the bayonet based LED's are somewhat limited, the chip boards are much brighter and focused where you want the light and can be used in situations where it would be difficult to use a bayonet base led "bulb", I'm using the COB LED boards in fixtures that are very much better looking than RV fixtures they were originally meant for AC use.
                              • Freeesun
                                • Oct 2018
                                • 144
                                #120
                                Single copper conductor wire or cca 10 gauge?
