How much for an off grid system ?
  • CracklePop
    • Apr 2018
    • 9
    I'm familiar with solar & wind. I did it in NE Arizona, but didn't have enough bucks to do it right. That was years ago. Things have improved. I might try it again in Southern Colorado, but need to know roughly what it will cost me. Not too sure about panels made in the orient. My last electric bill said I used 12 kwh. Maybe that will help you answer this question. I forgot to say it would be a hybrid system using wind, solar and a gas driven battery charger.
    Thank you ..... Alan..........Monday:
    Huge amount of embarrassment here. My wife had the electric bill tucked away and IT SAYS ( Drum roll ) "kWh used 310".
    Last edited by CracklePop; 04-23-2018, 01:23 PM. Reason: Big mistake - Please see original post for editing
    • 15048
    How long did it take you to use 12 kWh ?
      Generally, if you don't have to tie your hat on when you go outside, you don't have enough wind to be really useful
      12kwh daily. Wow, that's pretty hefty ! Days when I pump water for 4 hours, I use 11-12kwh I started with a 3kw array, but unless weather was perfect, I seldom completed charging and had to fall back to generator. now with 5kw solar, I only use generator on 2nd cloudy day
      • CracklePop
        • Apr 2018
        • 9
        OMG .....That's a monthly quote not a daily one
        • Matrix
          • Oct 2017
          • 360
          I have a system that gives me about 5.2 kWh of power per each full charge at 50% DOD. Cost was a $1.35 per Watt at 5.2kWh's.
          285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4
            • 15048
            So, pardon my ignorance, but just what does that mean ? Is that 12 kWh an average daily use over a month or 12 kWh use for an entire billing period ? Or what?
              12KWhr a month is almost nothing; you're already paying so little that solar is likely not going to save you much on your bill. Even here in the land of expensive power you'd be paying $3 a month plus a minimum. Might take you up to $6 a month.
              • CracklePop
                • Apr 2018
                • 9
                My original post said it was an off grid system (in the boonies). I'm not going to waste my time with solar in my present location. There are too many lights screwing up my interest in astronomy so I want to move. Q. Why are neighbors so inconsiderate ? Okay.....Typically DOD stands for Dept of Defense. What does it mean in your post ? Thanks .................................................. .................................................. ......................................... My1stDome.png
                • CracklePop
                  • Apr 2018
                  • 9
                  I should call my electric company and get them to explain that monthly figure on my bill
                    12 Kwh/month. I have a very hard time believing that. That is 400 watt hours per day. That would be something like a laptop with a small LED light.
                    • Matrix
                      • Oct 2017
                      • 360
                      System is what would be considered off grid as it is not attached to the grid at all and all the loads that it handles are connected to it. It is small/medium an can handle 3400 watt loads with 6000 watt starts and 4000 watts for 30 minutes. There is 5.2kWh's of energy storage available before the batteries are at a DOD (Depth of Discharge) of 50%. How long it takes a person to burn thru the batteries energy storage depends on the users Watt hours used per day which is determined by a detailed in house energy audit - that u can do yourself with a simple Kill-a-Watt meter.
                      Also it is not best to use 50% of the battery all the time for longer cycle life, but 50% is the number used for usable storage of flood acid batteries before you do harm to the batteries from over discharge.
                      • CracklePop
                        • Apr 2018
                        • 9
                        After your informative post, so do I
                        • CracklePop
                          • Apr 2018
                          • 9
                          Sounds like I should buy more batteries and panels especially for those overcast days. I have to find out how much of a drop the panels have on a gloomy day
                            Average cloudy day, expect 10% of nameplate. Real gloomy, one day I harvested less then 500wh from a 5 kw array. Generator time
                            • CracklePop
                              • Apr 2018
                              • 9
                              Huge amount of embarrassment here. My wife had the electric bill tucked away and IT SAYS (Drumroll) "kWh used 310".
