This looks like a very simple, cheap and effective solar tracker for small systems. Scale-able too I would think.
Simple solar tracker
looks cute and pretty much will cost more than doubling the solar panels which would be far more effective.This looks like a very simple, cheap and effective solar tracker for small systems. Scale-able too I would think.
Not sure why people try to over complicate things with tracking.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNH -
Years gone by, it was much cheaper to build a tracker, due to panels being so costly. Nowadays, you would be better off by adding a few more panels to a static mount.This looks like a very simple, cheap and effective solar tracker for small systems. Scale-able too I would think.
PaulComment
The tracking mechanism is the easy part. Various methods have been around for a long time. The cost and design and maintenance considerations for a moveable support system are the more challenging parts.Comment
I was looking at the trackers from Home CSP and solar stalker. I have no idea about the reliability of these units? Seems like a few DIY people are using them.Comment
Not sure about the tracker itself, as I have never bought one from him. But, the mounts (that he used to make?) seem to be pretty beefy:
With that said, I have attempted to contact him a few times, over the years. To date, he has never responded to me. Maybe he doesn't like the way I type?
PaulComment
It looks pretty enough, but incomplete. Things like that I build have grease fittings. I really wonderNot sure about the tracker itself, as I have never bought
if it is now actually operational?
Someone near here built a group of small tracking arrays. When I read he also
used batteries, I figured they were more for show than go. I should find them
and see how they are doing. Bruce Roe
I found this guy Craig Bradley on youtube built his own mount and is using the Home CSP tracker. I think his install is a couple of years old. I will try and contact him and see how it is holding up. https://www.youtube.com/watch?v=nqgu1F6NBHQ
I emailed Mr. Bradley and he was satisfied with the Home CSP tracker. His mount was good, but he would not use a pin in the bottom of the mount again. He would weld a cap on the bottom.Comment
