If you go into TV settings the backlight, not brightness, can be turned down saving more than 30% power. My TV was sold with a 12V wall wart. These were common about 5 years ago, not so common these days. I run a buck boost converter to get stable voltage.
Off Grid Set Up
What is the consensus on sizing batteries for 3 days, going with AGM batteries to avoid the min. amps need of keeping a FLA happy, and using a small array that takes 2 weeks to top off the battery since it is only used once a month?Comment
AGM isn ( damn apostraohe crap, can apostrophe T ) admins fix this ) not going to like a 2 week trickle charge either.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
What's the problem with apostrophe? Let's play with it. Real easy to fix.
'''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''''' ''''''''''''''Last edited by Sunking; 01-05-2018, 12:45 AM.MSEE, PEComment
AGM certainly has niche applications, but you had better justify the cost using them. At the end of the day is 400% higher cost than FLA. AGM cost twice as much as FLA and only last half as long as FLA. So be careful what you ask for. There are only three reasons that come to mind to select AGM over FLA.
1. Spills cannot be tolerated. This is why AGM were invented by Concorde for military aircraft.
2. Very high charge and discharge rates. If you only size for 3 days is going to be a high charge rate.
3. Extreme cold climates like high altitude or where temps drop to -40.
MSEE, PEComment
I was thinking another "special use case" might be called "very slow charge rate" and avoiding having to install are larger panel system/charger than needed for the loads without having stratification problems of a slow charge. The question was coming in at the price of batteries vs the price and complexity of a larger system.Comment
AGM is not immune to sulfation. If it sits long enough, below 80% charged, it's going to start to sulfate after 48 hours. If your solar cannot get the battery back to 80% within 2 days....
you could use a genset to boost it up just before you depart.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
apparently apple products use a different apostrophe that this forum does not like. This is a new thing. It was not acting this way before.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
This seems like a pretty typical use case. Someone visits their cabin every couple weeks, doesn't want the noise of a generator, and doesn't want to put a lot of money into the project due to either financial sense or risk of theft/vandalism. Is there a better battery technology suited to this use case?Comment
The batteries are more expensive than PV modules so if you are worried about theft worry about them.
or as already been suggested recharge the batteries before leaving and let the solar trickle / maintain them till you come back.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
For cell phones and tablets there is APPLE Ios that is not compatible with anything but APPLE. Then there is DROID (UNIX) which is a universal standard everyone understands and works with. All Servers use APACHE which is a UNIX code.
Now having said that VB software can have a Plugin to translate APPLE, On Mike Holts Forum we did that years ago. The guys down under I can only assume do not know how to fix it. Just like the PM function does not work here. DIY Admins cannot figure out how to make it secure. They need an IT NERD.Last edited by Sunking; 01-05-2018, 05:03 PM.MSEE, PEComment
Kind of like owning a model train layout using "s" gauge track and scale (the old American Flyer scale) and about 90+ % of all the model trains in the world are "O" gauge (like what Lionel use and had ~ 90 % of the market).
Apple may have good products but IMO and experience, most (but not all) of the really technically savvy engineering and technical types I know and have worked with don't take Apple computer products very seriously and so don't use them. Often at least to my observation, Apple computers are more often the choice of technical wanna be's and dabblers than of serious nuts & bolts types who actually produce results and designs that work.
I don't own or use any Apple products and I don't seem to have ever had machine induced problems with punctuation. But then, correlation is not causation.
But, if I needed to change my writing style to accommodate a communication tool, or that tool hampered my ability to communicate, that tool would be outta' here faster than a calculator with keys that stick.
Just my $0.02.Comment
