First post to the forum. Probably a pretty basic set up but I would appreciate some opinions before I spend the money. I have an off grid cabin in a river bottom located about an hour from Houston, Texas. I would like a setup that will power about a 10 watt radio for 12 hours a day, 7 days a week. There are also times when I stay at the cabin that I may run a TV and a few LED lights at night for maybe about 5 hours each night. I am basing this set up off the usage of 5 hours per night for three consecutive nights at most. By reading the sticky I have figured these numbers:
- 200 watts x 5 hrs/day = 1000 watt hours
- 1.5 fudge factor = 1500 watt hours
- I kind of guessed that 5.5 sun hours is good
- 1500 watt hours / 5.5 = 273 watt panel array
The next calculation of battery amp hour and controller size kind of confuses me
- 5 x 1000 = 5000
Based on 12 volt system 5000/12 = 416 amp hour battery, or I could use a 24 volt system =208 amp hour battery
Now the controller confuses me too. Panel wattage is 273 so if I use the 12 volt system the controller would need to be a 30 amp MPPT I'm thinking, or if i use 24 volt system the controller would need to be 15 amp MPPT if one that size is available. So, does this sound like I am on the right track? If it ends up being more expensive that what I want spend I may just base the system off the usage of a 10 watt radio for 12 hours a day. I have a Honda EU2000is that I can always use for the TV and lights anyway.
- 5 x 1000 = 5000
