You aren't paying for anything. You are contributing your fair share.
From each according to his ability (to be taxed).
Powerwall 2 install.
You got it, which is why the calculated differential was .25/kwh between peak and semipeak.
So it takes all those subsidies to approach a 10 year simple payoff, IF the battery performance doesnt degrade. I guess IF poco peak vs off peak rate differentials increased, it could help. But in PGE territory their resi plans have collapsed the TOU period rates down much closer, ie flatter, making peak shaving a much harder payoff. And likewise on tiered plans, with the exception for the 400% tier they have a .20kwhr diff between t1 and top tier.Leave a comment:
Yes that's right one enphase micro inverter per panel. PV system was 3.2 per watt approx
The gateway is shipped with the battery. It has all the software and firmware and power management logic connects to your home network and to Tesla updates itself with the latest software and sends analytics to you and diags to Tesla.
Thank you, they have interesting component there called 'Energy Gateway' which I assume would be the 'brain' of the whole setup- did you get that installed as well and included in the cost above?
How much did PV part of the system cost for 7.4kW array? I understand the inverter is built in into PowerWall so that must have provided some savings on PV side of things.Leave a comment:
Yes in fact it is priced into the car. Recently they started unbundling this as a separate charge for new owners.
Totally agree nothing is free. I'm my case I'm simply getting something that I've paid for and not using sufficiently lol
Also agree with the comment regarding taxes. I live in Cali you pay for the privilege ?
those practices for one as nothing is truly free, ever. Someone pays for the supercharger station and I wouldn't mind if Tesla charged owners of their cars up front for the life of charging if they wished so but they went beyond that and trying to make it 'free' at the expense of business owners at the plaza where Tesla owners go shopping. Now that have me objecting as those owners would need to channel the charges down to the rest of the public. I think we have enough taxes from the government to have private company impose their own on top of that. That's besides various subsidies they're getting from the government as well. I fully admit their products are innovative but somehow leave bad after taste and thought 'scam' crosses my mind too often when it comes to those enterprises.Leave a comment:
op used microinverters and AC coupled the battery, so no coordination between PV and the battery is required for load shifting. With respect to rates, sgip requires 75% of the charge come from pv, so it looks like 25% could come from the grid overnight at the lowest rates.
In San Diego, op would qualify for an EV plan with 12-6 pm peak all 7 days of the week, maybe a better fit for the production profile. In a few months, non-grandfathered plans will have a later peak period (and more semi-peak), so the economics get a little better.Last edited by sensij; 07-15-2017, 01:18 PM.Leave a comment:
Thank you, they have interesting component there called 'Energy Gateway' which I assume would be the 'brain' of the whole setup- did you get that installed as well and included in the cost above?Here is a link to the units specs.
I think some of your assumptions are off - how system would charge battery in semi-peak period if it is defined as:
Summer Semi-Peak 6 a.m. 11 a.m. and 6 p.m. 10 p.m. Monday through Friday, excluding Holidays
I don't recall a lot of PV production in those time frames. Unless of course those PowerWalls can simply be charged off the grid itself in off peak which would probably be cheaper than PV energy.Last edited by max2k; 07-15-2017, 12:27 PM.Leave a comment:
Max load should be somewhere in the specs- how else did they pull permit without supplying those details? For one it would define size of the breaker ... Don't get me wrong, I wish this project complete success despite my reservations against Tesla practices in general, I'm just trying to paint more realistic picture.Leave a comment:
Don't know what you mean by Tesla practices unless you are talking about solar city who were not part of this job in any way. I do own a model S and it's the best car ive driven. Teslas products are highly innovative and I think their energy storage products will create a new market segment. The cars the one thing whose consumption I left out if ask the calculations as there's a free super charger 10 minutes awayLeave a comment:
Thanks guys yes this is an awesome deal afaict. Enphase microinverters for each panel on the roof and no standalone inverter in the garage other than the one inside each powerwall. Brand new construction. Like you said think I have enough PV capacity and A/Cs run only for a short period every year. We get so much high quality sunshine here on the southern roof that most of my neighbors have no electric bills with 3.5 kW systems. While I've worked out the pv system break even approximately (we are new to the area and tou plans and simply don't have enough consumption history) I've not thought through the break even period for the battery yet.
I'll keep you posted on actuals.
Another big convenience is that the powerwall app which is built into the Tesla app should give need me continuous useful analytics.Leave a comment:
A 7.4 kW PV system is larger than average and looks like plenty to me. My 8.1 kW system is putting out 48 kWh daily this time of year, so the OP should be fine supporting a 27 kWh battery on most moderately clear days.
The powerwall 2 is rated for 5 kW continuous, 7 kW peak. Two of them should be double that, if there are no other limiting components.
The SGIP requires an average of 100% discharge weekly, so let's use 4 kWh daily.. In SDG&E territory, let's assume DR-SES rates. That means that the battery would charge during semi-peak and discharge during peak. The differential is 0.25/kWh, and only applies during weekdays in summer. Let's call it 132 days.
If just 4 kWh are cycled at 90% efficiency, that is worth $118 per year. If all 27 kWh are cycled, it would be worth $832 per year.
If the two powerwalls alone cost $5320, there are other storage specific costs to consider (Storedge inverter is $1k more than regular inverter, if that is what was used). Simple payback under 10 years looks possible.
So, given that two units cost $5,320 (not sure how much more 3 or 4 units would cost depending on the limits of the rebate). Given your potential savings from TOU load shifting, any thoughts on the break even period? Ideally it would be less than 10yrs given the limited warranty (and lifetime) of batteries.
But, solely as a backup power solution (aka no ROI needed), it's actually very compelling with the rebates. A decent ~22kVA generator is $8-10k plus installation (aka $15-20k installed) AND much more expensive to run on natural gas. When Sandy hit here in NJ, my neighbors with whole house natural gas generators were looking at a $200-300 per day in natural gas bills.
I'm not aware of any such PoCo rebates for storage here in NJ.Leave a comment:
Here are some of the specs:
https://www.tesla.com/sites/default/...ers_Manual.pdf
Looks like 5.8kVA max continuous per unit. So that's 24amps @ 240VAC per unit. Which given 13.5kWh would be ~139 min at 100% load. If two units are perfectly parallel, that would be 48 amps continuous @ 240 VAC for 139min.
Overload capacity, per unit appears to be 7.2kVA for 10s. So that's 30amps, per unit (60amps max theoretical for two) for 10s. If you have a newer, more energy efficient AC with multiple stages and a DC blower it MIGHT start. But, I highly doubt such a system design would pass permitting and inspection. You'd either need to automatically load shed the AC, or scale up with more PowerWall units.
When I was playing with their website, it appeared that you could parallel 3, 4, 5 units, etc. If you really want to carry your entire 200amp panel with your AC, I would expect that you would need at least 3, perhaps 4 units. AKA 17.4kVA (3*5.8) or 23.2kVA (4*5.8) in the same way as you would for a whole house generator. If you automatically shed your AC, then two are probably sufficient depending on your desired load and runtime.
