Really appreciate those pictures. I've wondered what those controllers had inside.
Is my MPPT CC killing my 12V AGM battery at 16V?
Well, it looks like it's a legit MPPT controller. I guess you have to report back to us, as to how well it works
Edit - the EPSolar Tracer 2215bn spec looks like it might be MPPT. the only pics I've seen were of the Bogus controllerLast edited by Mike90250; 11-21-2016, 11:57 PM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I fail to see anything in this that would make this a MPPT controller except in wind turbine use. I do like the external current carrying bars to the FETs rather than relying on copper foil with built up solder. Great picture quality. I appreciate those who can take a good photo. I do think the controller is somehow to blame.Comment
Is this based on direct manufacturer information?
Or the posted specs?:"Then I took a look at the specs of the Controller:The 48V input and up to 380W panel power with 30A nominal 12 output are all consistent enough, but unless they use a really high frequency and some of what appear to be resistors are really inductors, I just do not see support for that in the photo. Of course we can't see what is between the circuit board and the heat sink either....
Maximum Power Current: 30A
System Load loss: < 13mA
Loop Buck: < 100mV
Battery Float Voltage: 13.8V
Discharge Stop: 10.6V
Discharge Resume: 12.6V
Temperature compensation: -4mV/Cell/˚C
Solar panels maximum open circuit voltage: < 48V
Peak power of solar panel: 380W"
Need I say more, I'll leave that to others. Firm believer in they always shoot the messenger.
I'd love one that is damaged and out of warranty.Last edited by PNPmacnab; 11-22-2016, 10:02 AM.Comment
I just got the 2215BN today and it totally solves my problem. It might be one or two sizes to big for my setup, but this way i can put up another 13 panels when I need more power down the stream. For those who are interested in what it looks like on the inside, I made some photos. It is actually a lot bigger and heavier (1.5kg), than I thought.
2215BN-1.JPGComment
Interesting pictures, thank you.
The contents of the black potting at the top of one photo appears, from surface irregularities, to be two toroidal coils, a good indicator of true MPPT.
But the input side working range from 8-32V is hard to understand.
It may be able to withstand an input Voc from panel string of 150V, but if the MPPT range peaks out at 32V it is not clear how useful the unit really is.
I hope that that is just a misleading printed spec.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
I think the 8-32 is the battery side limits. Below 8V (at night) there isn't enough voltage to run the internal electronics and above 32V from an external source like another controller could damage it..Comment
Probably, but the spec is found grouped with clear input specifications on the input side of the label, not the output side.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
