Off grid system, safety disconnect
  • maple flats
    • Oct 2011
    • 108
    I am at the final phase (I think?) making my 1.71KW off grid system code compliant. My situation before the question. I have 6 Solar World 285W panels, wired as 3 strings of 2. As they first enter the camp they go thru a Midnite Solar combiner box (MNPV6) with 3 din rail breakers at 15A ea. From there they wire to a system control box (MidNite Solar MNDC125) with a 125 main, a 63A with a .5A side for GFCI and a 2A breaker for a battery SOC meter and a 60A disconnect all running off the GFCI breaker. From there power runs to a TriStar MPPT 60 and back to the MNDC125 box. Then I have 4/0 battery cables to the Outback VFX3524 inverter and out of the inverter it goes to a main AC panel thru a 30A main breaker. Also from a MNDC125 box are the 4/0 cables to the battery box, which is fully enclosed and vented to outside using 2" PVC pipe with 2 long sweep elbows in cellar, plus a third pointing down outside to exclude rain.
    Now, my question, I need to add a DC disconnect outside, where the conduit enters the camp. I bought a Sq D safety switch H362RB rated for 60A DC.It has 3 positions for 60A DC fuses, but I only have 3/4" conduit to it, thus I can only run 4 conductors in 6 AWG THHN to it. Which do I switch? I'm thinking Neg. from the MNPV6 after the 3 series panels are combined. That would be 2 wires 1 out and 1 back in, plus a ground. Is this correct? Or do I switch the Pos? Or do I need to change to 1" EMP and switch both Neg and Pos plus a ground? Or can I run POS and Neg out, and switch and use the EMT for ground?
    6,32 KW solar, net metered, maple syrup producer.
  • maple flats
    • Oct 2011
    • 108
    Having determined that New York State officially adopted NEC 2014 on 10/3/16 I guess I need to do it much differently. I now need a 1 point disconnect that will break all power in multiple locations with the push of 1 button, accessible outdoors for fire depts. etc. Thus I guess I will be getting a Birdhouse and a couple of other boxes to satisfy the new requirements. Or some other method. I'll have to see what the options are.
      • 3802
      you also need AFCI. But since you are using OutBack inverter you could use the OutBack Flexware ICS Plus
        Don't change anything right now. Wait for the next code cycle and your troubles go away.
        • maple flats
          • Oct 2011
          • 108
          I'm not sure it can wait. The codes officer (the one who originally said I didn't need a permit and then later sent us a letter saying we needed one and could be fined because we installed the system without a permit) is now pushing for the application to be completed. He has now threatened making us remove the system if we do not comply.
