inverter fuses blown
it is reliable. solarix has provided the answer to this inverter problem. its stuffed. nothing i did blew the fuses on this inverter. i agree i do need people with more experience than me to make it safe hence why i post pics and put questions to the members here.Comment
Sadly, a infant just died in a fire nearby, when a "safe" portable propane heater lit a trailer on fire.
Just because you can buy something and connect it to something else, does not mean it is safe.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I am just saying that someone with electrical trouble shooting skills and tools could have saved you a few fuses by determining the inverter was bad. A pretty basic step would not be to just install another set of fuses to see if the problem has gone away but to first determine what is causing the fuses to blow. Try to fix that first and then test with a second set of fuses.Comment
thanks, i guess i wanted to make sure the inverter was stuffed b4 i claimed the warranty. the fuses were only $4. its a $200 inverter so i dont think trying to repair it is worth while. but from what i observed when i removed the bottom plate.. a pool of brown liquid like honey , any ideas?
More than likely a component (ie. capacitor) overheated which resulted in its insulating material turning to fluid.thanks, i guess i wanted to make sure the inverter was stuffed b4 i claimed the warranty. the fuses were only $4. its a $200 inverter so i dont think trying to repair it is worth while. but from what i observed when i removed the bottom plate.. a pool of brown liquid like honey , any ideas?Comment
i think it is a capacitor too, the big capacitor on the right in the pic had a heat blistered plastic cap that was falling away. i removed the burnt plastic cap b4 i took the pic. reading some articles electrolytic capacitors are one of the main causes for inverter failureComment
I hope the problem was just a bad capacitor and not something else. Based on your description of the plastic wrap it was the capacitor that got over heated and failed.i think it is a capacitor too, the big capacitor on the right in the pic had a heat blistered plastic cap that was falling away. i removed the burnt plastic cap b4 i took the pic. reading some articles electrolytic capacitors are one of the main causes for inverter failure
Now while it may not be important, the capacitor failure could be the result of external reasons (overload, reverse polarity, voltage spike, etc.). So be aware that a new inverter might gets "stressed" if it is exposed to something it does not like.
Keep us informed of your new system when you get it up and running.Comment
my system is always running because i need it for my electricity. from reading about inverter failure i understand that electrolytic capacitors will fail eventually. the paste slowly dries out. inverters last longer if they run light loads. this inverter was 1700w, probably not enough for the appliances i use. so i suspect i shortened its life running maximum loads on it like 1450w coffee machine. if the warranty is not given i might try replacing the capacitor later on. you can get cheap 2000w modified wave inverters for under $70au. i might use one of those to run higher current drawing appliances.
Mike - THANK YOU. You just saved my ass. I use modsine for led lighting, and of course, this is going to fail if my strips have mov's - which are already about a decade old. Thanks for pointing this out, I had totally overlooked that.Comment
There is one thing about being frugal and under limited resources - we understand that. But buying *critical* pieces of gear used from unknown outlets is always a crapshoot. Especially if those devices come from about a decade or so ago when fake capacitors were rampant in the industry. (mostly due to industrial espionage where half the formula was stolen, and the stabilizing agents were left out). Fooled a LOT of good manufacturers. and OEM's.i think it is a capacitor too, the big capacitor on the right in the pic had a heat blistered plastic cap that was falling away. i removed the burnt plastic cap b4 i took the pic. reading some articles electrolytic capacitors are one of the main causes for inverter failure
The reason we're being hard on you is that we don't want your trash-pile to kill you. Harsh, but deep down as humans, the last thing we want to read is an RIP notice here.
Find a way to test your power FETS before you spend time and money changing out caps. If the failed caps also fried the FETs, you will have to get matched sets to replace them too, If you can still find them. Substitute parts may need all the biasing re-adjusted, or it may need adjusting anyway,Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I agree with you. Electronic component failures usually have a cascade affect where other components become weak or fail besides the ones that you can easily find.Find a way to test your power FETS before you spend time and money changing out caps. If the failed caps also fried the FETs, you will have to get matched sets to replace them too, If you can still find them. Substitute parts may need all the biasing re-adjusted, or it may need adjusting anyway,Comment
inverters really are the weakest link in PV. especially the large 2000w ones. another pure sine wave inverter crapped itself. they dont like hot days. from now im using modified sine wave only because they are alot cheaper. doing away with high wattage appliances, going to get a gas / DC fridge. stick to smaller cheaper inverters no more than 600wComment
