Might work, but probably won't. Here's the troubling phrase:
"ACCEPT 18V TO 34V solar panel"
A real MPPT controller accepts higher voltages than that. If your highest array voltage is 18 volts you won't get any benefit from an MPPT controller on a 12 volt system, and if the highest voltage the thing can handle is 34 volts it won't even work with most 24 volt systems. (Open circuit voltage on a 24 volt array is around 40 volts.)
I suspect this is a standard PWM controller with fancy wording.
In general, you get what you pay for.
