Inverter fans run most of the time?
  • dlarson59
    • 9
    Hello, I have a new Schneider Conext SW 4024 inverter that fans run more hours then not?? From what I can find out, the fan should kick on when the internal temp reaches 113 degrees F. The room temperature and the battery temps are in the 70's. I have heard that there may be an issue with the firmware loaded into these units and that 3.+ and up version corrects this issue, I'm running a 2.+ version. Anyone have more info on this issue?
    I'd say look into having your dealer update your firmware, if you don't have a Combox to do it with.
    My XW inverter gets pretty toasty (about 2Kw in loads) before the fan comes on.
    • ZEUSHP
      • 8
      I have the same inverter, the fans are on all day. only go off when the ambient temperature is below 80°F
      • dlarson59
        • 9
        ZEUSHP,
        I call Schneider and they are sending me software and equipment to load updated firmware. I will wont be back to my cabin for a month but will repost if this corrects this issue. Dave
        • ZEUSHP
          • 8
          ZEUSHP,
          Thanks Dave for giving me that information. I'll be calling soon
