Hello, I have a new Schneider Conext SW 4024 inverter that fans run more hours then not?? From what I can find out, the fan should kick on when the internal temp reaches 113 degrees F. The room temperature and the battery temps are in the 70's. I have heard that there may be an issue with the firmware loaded into these units and that 3.+ and up version corrects this issue, I'm running a 2.+ version. Anyone have more info on this issue?
Inverter fans run most of the time?
I'd say look into having your dealer update your firmware, if you don't have a Combox to do it with.
My XW inverter gets pretty toasty (about 2Kw in loads) before the fan comes on.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hello, I have a new Schneider Conext SW 4024 inverter that fans run more hours then not?? From what I can find out, the fan should kick on when the internal temp reaches 113 degrees F. The room temperature and the battery temps are in the 70's. I have heard that there may be an issue with the firmware loaded into these units and that 3.+ and up version corrects this issue, I'm running a 2.+ version. Anyone have more info on this issue?Comment
ZEUSHP,
I call Schneider and they are sending me software and equipment to load updated firmware. I will wont be back to my cabin for a month but will repost if this corrects this issue. DaveComment
