Do you have any recommendations on how to make an installation of a solar panel with battery and a voltage converter for a 55w laptop? I need it to work 8h a day.
How to make solar panel for laptop 55w
Yikes, That is all power needed from batteries, no sharing from direct solar contribution.
You will need to size a system to harvest and store 2x (twice) as much as you plan to consume. All the operating losses are going to add up in a bad way on you.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
It is not that bad, it is only 55watts, 8 hours is about 440 watt hours. if you only need power for this laptop, I will just get a 250 watts panel and a cheap charge controller and a cheap 12 volt inverter about 150 watt or 300 watts plus 1 12volt 200 amps deep cycle battery.Comment
If you already have the AC adapter for the laptop, going with an inexpensive inverter may be best. But you will get better efficiency by buying a 12-18 volt DC input car/airplane power brick for the computer. That will also be usable when you are away from your solar system.It is not that bad, it is only 55watts, 8 hours is about 440 watt hours. if you only need power for this laptop, I will just get a 250 watts panel and a cheap charge controller and a cheap 12 volt inverter about 150 watt or 300 watts plus 1 12volt 200 amps deep cycle battery.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
