Thank you very much....
25W of solar panel question
Hitachi air blower
Hi, could somebody design solar system for following specification;
Air blower:-
1) Phase - 3
2) Poles - 2
3) Capacity(m3/min) - 1.2
4) Pressure(kPa) - 13.7
5) Shield Bearings - 6306/6205
6) Insulation - B
7) Cycles - 50/50
8) Max.output - 1.6kw/1.6kw
9) Volts - 220/415
10) Amp's - 8.2/3.7
11) Max.Operation Pressure(kPa) - 19.6/19.6
12) Operation time per day - 12 hours
13) Place to install - Malaysia
ThanksComment
Air blower:-
1) Phase - 3
2) Poles - 2
6) Insulation - B
7) Cycles - 50/50
9) Volts - 220/415
10) Amp's - 8.2/3.7
ThanksComment
25 watt solar panel and 17 ah battery
it will be better to use dc load . 25 watt solar panel can properly charge a 17 ah battery and if use dc lights and dc fan to run your battery will last longer .Comment
5 LED lights, say 5W each, 1 fan, 25W normally, so total power consuming is 50W. For 8 hours working time, need one 12V 36Ah battery, 5A solar controller.Start with [URL="http://www.greenbaba.com"]solar power[/URL]Comment
