25W of solar panel question
Batteries can't be trickled charged from "dead". There are minimum charging rates to bring a battery back to "full". Additionally, batteries really need to be chosen carefully, you can't just get a car battery and try to make it work. Sure, you can replace the battery every two years, but a proper solar system battery can be made to last 5, 10, 20 or more years. Who wants to replace batteries all the time?
In the OP's case, they've not stated the operating parameters of the solar panel. So all of this is just guessing.
Solar power systems need to be =designed= and not just thrown together. And that even applies to little systems that are just providing power for a few LEDs and a fan. For a 25 watt array on a 12 volt system, the largest practical battery is going to be between 25 and 50 amp-hours. 50 amp hours is really pushing it as the maximum charging rate is going to be about 3% of capacity (25 watts / 15 volts = 1.67 amps, 1.67 amps / 50 amp-hours is about 0.033) So, a 25 amp hour battery is a much better choice.Julie in TexasComment
i got it now, for stable and safety purpose, i need to put at least 320W of solar panel to support my 320wh led light, am i right? By the way, usually what is the average of recharge time for a watt? Thanks.Comment
lsy388, I think we need you to clarify whether your LED's and fan will be consuming 5W or 50W.
It would also be nice if you could tell us the specifications for your 25W panel, or give us a part number or something.-
Alexander Hayman
Electrical Engineer
[url]http://www.genasun.com[/url]Comment
Who'd 'ave thunk a 25W panel would get a thread this big?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi, may i know 1.8W mono 125*125 cell can charge how many watt per hour in Asia region? Kindly advice, thanks.Comment
LOL...no kidding Mike. And I read this thread word for word????? Maybe it's a great story, newbie in Malaysia getting help from "engineers" from around the world. The internet is amazing.[url]http://newworldsolarpower.com[/url]Comment
I wonder how much a 48v 25 watt trickle charger solar panel combo would be for my mini van or if such a thing existsComment
Hi, can somebody tell me what actually mean 12V 7AH at lead acid battery reading? How could i know total load at watt for the lead acid battery? Thanks.Comment
Volts x Amps = watts Your battery 12v x 7ah = 84watt hours.
of that, half is useable, or you begin to damage your battery.
84 watt hours = 84 watts for 1 hour, or 42 watts for 2 hoursPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks body, by the way, i still don't get the reading of (20 hour) at the battery, such as 12V 7AH (20hour). Kindly advice, thanks.Comment
LoL, first of all a 7AHR battery isn't going to run much more than a flashlight.
2nd Batteries are rated by capacity OVER a specific amount of time. The faster you draw current the LESS capacity you get. Reason being that there is a lot of resistance and "losses" associated with drawing current quickly.
In other words that battery will provide .35amps for 20 hours and then will be permanently damaged and basically unusable after that amp draw.
If you were to draw much more current than .35amps you will not get 7ahr more like 1-4ahr depending on how fast you draw.
So to put it simply you only get the amount of capacity on the label if you draw the current over the rated period of time. Take longer you get more capacity, take less time you get less capacity.
And everything stated by Mike is correct, you can only use 50% of the batteries capacity if you intend on using the battery more than once.
So in reality you can draw .35amps for 10 hours and then recharge on that battery or it will be permanently damaged.
Cheers
RyanComment
