NiFe Electrolyte Refurbishment/Replacement 8-20128 (& DIY battery inverter )
JPM, none whatsoever. Just adding to the humorous side of this post.
Sorry if you didn't see it for what it was. Guess I should have used the Comic Sans font.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Got it. Among other things, I've been accused more than once of sometimes taking myself all too seriously. I try to keep the persistence of such comments in mind. I just took a deep breath.Comment
About 3:30 pm, I finished all the bolts and cable re-connections, and switched back to the NiFe bank. Mercifully, it was uneventful. (no earth shattering Ka-Boom )
Re-programed all the chargers again, and we're charging back up to full power. Might take a couple days, got a lot of smoke blowing in, today was very hazy, but the haze may extend my charge time till 6pm from all the bright scattered ambient light.
Off-sunlight hours, I keep the 4 marine batteries on float with a honda EU-2000, about 80 hours, and 8 gallons of fuelPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hi Mike, first I will say I hope that the fires are not causing you immediate risk. We have them here too and there are shocking. I've just joined solar panel talk and I found you. A rare species that actually uses NiFe batteries. I'm embarking on an off grid build myself for retirement and I'm in a bit of a quandary about batteries. Despite all the bad stuff spoken about NiFe batteries I have been leaning in that direction for a while but the Lithium scenario is throwing a curved ball at me. Efficiency doesn't worry me a great deal as PV panels are now quite inexpensive and I intend to have a wind gen too as the site is quite favourable. It means that I can probably have less capacity and more input. I guess I'm asking would you still go with NiFe. Given your background I suspect your opinion is really worth having and you are after all walking the walk. I have a pretty useful skill set and watering etc. doesn't phase me too much and I think my 2nd leaning would be towards flooded lead. Gel etc seem to be for those that want to set and forget - generalisation I know. Any thoughts would be much appreciated, and I get that you are up to your eyeballs in chemicals at the moment so NO pressure, Best regards Dave.Comment
Well, the bank is back in operation, shoulder is sore from a day with the big torque wrench. I'm not sure I can perform another change out in 10 years, it's a job for 2 younger men, not an old fart with a replacement shoulder. Otherwise, I love not having to worry in the winter if they are charged enough to not sulfate. Panels ARE cheap, having installed the 2nd array for SWMBO morning toast, also provides an redundant array and CC.
The terminal bolts are 20mm with 30mm nuts:
While bolting the tie links in, I left a couple out, so if something untoward happened, it would not have the whole bank behind it, and I also us a marine battery disconnect switch in the middle of the bank, by the door, as an emergency shutdown.
Thanks for posting these, it's an impressive setup, especially compared to a lot of the hokey stuff I see on the web.Comment
It's one string, done mostly right, but so long, it wraps around the room.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
2 very good ideas. Impressive but way more work than I would want to do. Bruce Roe
I'm sorry, I didn't catch where you may have said what prompted you to go ahead and change the electrolyte.
Is it just age/health concerns, meaning you are changing it while you are still able to? Or did you check the carbonate levels?
If you were to try and estimate, how much longer do you think the cells could safely continue to operate before really needing the electrolyte change?
TomComment
Yes.I'm sorry, I didn't catch where you may have said what prompted you to go ahead and change the electrolyte.
Tom
7 years since install, and because of labor and health issues, I did the change-out now. Cells would have gone another 5 years, but with diminishing capacity and increasing water usage.
Since the changeout- I've not had to add water because of the restored efficiency.
How many questions am I allowed? Because I have a few...
Let's start with this one...
Did you source the new electrolyte through your original supplier (BUF) if not do you mind saying who, and was the supplier helpful with instructions?Comment
Yes, I got the chemicals via the battery supplier, because now they cannot be sourced in california, and instructions were the same as the original fill.
So ask the questions in one post, 'cause I'm not going to do this piecemeal. I'll skip answers that I already covered in this thread.
