i am new in this forum
and i did not really now where to post this
so my question is
if i have 4 batteries and i want to connect them in series and in parallel so i increase both the volts and the amps
which configuration is best
2s2p or 2p2s???
connect the batteries in series and then in parallel or
first connect the batteries parallel and the parallel batteries in series?
both setups seems to be giving the same results
but from battery perspective is 1 design better?
as i see it in case 1 battery fails
2s2p case 1 battery fails so you loose the other battery so you are left with the 2 batteries trying to
power you so they get both double the normal amp to push
n case of 2p2s you loose 1 battery but then you have only 1 battery trying to push the double amount of normal amp
so i see that the design 2p2s has some advantages over 2s2p
second question
if you have a number f batteries lets say 5 for the argument
what will be better
put them all in parallel and just draw more amps from the pack
or put them in series and draw fewer amps???
so from battery perspective which setups is better for the batteries
parallel or series?
i have done some dyi in electronics and i know that in electric circuits
some designs may seem identical but electrical there is a huge difference
the order you put some components
thank you all for the replies
so my question is
2s2p or 2p2s???
second question
what will be better
parallel or series?
