I'm not so sure about that.  I think we have a different vision.  Since I am not sure what you suggest can be implemented with the equipment I am looking at, see if what I am suggesting stands any chance, or similarly you don't think it will work.  I was thinking the BMS thresholds would be never to exceed high and low values that indicate one or more cells has gone out of balance, started to malfunction, etc.  The charger/inverter and CC settings window would be fully contained inside of the BMS window.  I was going to use the BMS triggers, both high and low, to shut down the system.  The programmable thresholds of the CC and inverter/charger would be the ones "normally" used, both low and high.   Your vision is the high BMS threshold is where I would stop charging.  You say below that the low BMS voltage would mean it needs to be "recharged," but in my vision this may mean re-balancing might be due because that cell fell lower than the others.  We bottom balanced the pack.  Recharging is needed at whatever the low threshold is set at in the charger and CC, which I was going to set above the "never to exceed" low voltage.
Note: The input on the XW is a SYSTEM POWER OFF signal - shuts the XW off. I don't know that it will function as "charge is complete" signal as you suggest. It shuts off both the inverter and charger.
In my vision, something IS high voltage - the cell has exceeded the highest voltage we want it to see.
What I meant by that is, either the cell has degraded or it has gone out of balance. That's all. Instead of letting things get worse, shut down. Make the monkey (me) come along and figure out what cell has gone out of bounds, for whatever reason. Rebalancing is supposed to be rare, since LFP cells tend to stay in balance.
I want to terminate charge normally at whatever high threshold is set in the CC and charger for the entire pack. We bottom balanced, so I wouldn't have the exact same 90% SOC on each cell, but do I care? The BMS high threshold would be above that, and represent that I detected a high voltage on a single cell, not waiting to see it on the entire pack, which may mask the individual exceedance.
The XW is that, isn't it?
